Perform this procedure to reset the current configuration on Fabric IPsec Gateway Virtual Machine (VM).
enable
virtual-service WORD<1-128> console
Type CTRL+Y to exit the console.
reset-config
Reboot the Fabric IPsec Gateway VM after you reset the configuration.
Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> reset-config
